Will copper tarnish under finish? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=48141 |
Author: | James Orr [ Mon Aug 15, 2016 5:31 pm ] |
Post subject: | Will copper tarnish under finish? |
I've mentioned in a few threads recently that my current project is a koa and redwood small jumbo. The binding is macassar ebony. Because I have a lot of browns and reds, I think copper would look particularly good for "halo" fret position markers/fretboard dots, and found this copper tubing on Amazon. However, we also know that copper is known for it's oxidation. Do you think oxidation would be much of an issue if it's sealed under lacquer? |
Author: | Clay S. [ Mon Aug 15, 2016 5:57 pm ] |
Post subject: | Re: Will copper tarnish under finish? |
Yes, eventually. Most lacquers are not "waterproof". Although they will slow the transmission of vapors (water and air) they will not totally block them. Baked epoxy finishes, as used on brass instruments, work better, but may not be practical for position markers. |
Author: | SteveCourtright [ Tue Aug 16, 2016 1:55 pm ] |
I agree with Clay. Oxygen moves through wood too. |
Author: | Joe Beaver [ Tue Aug 16, 2016 4:08 pm ] |
Never used copper but I have used sterling silver. Used water based KTM 4 on one about 20 years ago and KTM 9 on one about 8. Neither has tarnished, but they probably will in time. Not sure it relates directly to copper but then oxidation is oxidation. |
Author: | Ruby50 [ Wed Aug 17, 2016 8:29 pm ] |
I have a 4+ year old sterling silver inlay with nothing but a bit of shellac over it and it still just just as lustrous as it was when I installed it. Ed |
Author: | James Orr [ Thu Aug 18, 2016 12:48 pm ] |
Thanks, guys. I've found some interesting resources over the past few days. This is a long Q&A type thread, but it references nearly all of them: Clear coating brass, copper and bronze furniture, sculpture, and jewelry Reading through these things helped me remember the thin coating of Z-poxy between the lacquer and copper, adding another factor to the mix. |
